i think that my starter has died a death.
used to work fine, but now it engages on the starter ring but the engine dosnt turn at all.
sometime dosnt engage just spins like crazy.
checked all the wires and the battary is fully charged.. also engine can be turned by hand.
what do you reckon? broken?
Garry
starter gone bonkers
Had similar issues the other day. Turned out to be a bad earth so the starter wasn't getting full current. Stupid PO had just twisted two cables together and taped over them
Took 3 years before it became a problem (and I noticed). In the middle of replacing all the old wiring now.
To rule out any wiring isues just connect the battery directly to the starter useing jumper cables. Positive the the batery side of the solenoid, earth to the starter body, or close by. And then use a littl bit of wire to energise the solenoid direct from the battery. If it still gives you grief its deffinatly your starter.
Hi ,
had a similar problem
fully charged battery, turned engine over to get oil pressure with plugs out, up after a long engine gearbox work. fitted the plugs starter would start to kick the engine round and then grind on the ring gear.
found that the battery was down on a cell and loosing power to start the engine over with plugs etc working.
new battery sorted my problem out
Andy
Andy
3.9 V8 Mini Van....THE BEAST
