How to wire up a Relay
On the dash vents of the GT40 I fitted 2 electrical fan heaters / blowers
They are rated at 168 watts each (See here http://www.cbsonline.co.uk/electric-dem ... -309-p.asp)
I had them coupled up to a single toggle switch but strangely enough the switches don't last with the current draw (sbout 28 amps by my calculation)
So I bought a fused relay rateda at 30 amps - but have never wired one of these before so could someone please assist.
I have on the relay 4 pins
They are marked 30, 85 , 86 , 87 (to me it would be more helpful if it said mains, earth, switch and heater element!
So is this a standard relay numbering ? or is it try it and see but make sure you have a fire extinguisher near by? (Oh and a can ot the Lucas wire fixer for when the smoke escapes?)
bodger
Post by bodger »
Many thanks - those diagrams make sense now!
Is it permissable to wire up the feed to the main / fused fircuit and to the toggle switch or does the toggle switch circuit needto be fused too? If so at what sort of amp rating
Ian Anderson wrote:Many thanks - those diagrams make sense now!
I dont fuse the low current side, as I'm usually drawing that from a fused circuit anyway.
So I can connect this up!
Do I do 1 relay with a 30 amp fuse that runs the 2 heaters
or
Do I do 2 relays (activated by a single switch) and each of them with a 15 amp fuse and then each relay runs 1 heater unit?
What is correct?
tetlow
Post by tetlow »
I would go for the two relays Ian.
That would mean if one fan has a problem the other will still work.
Post by ian.stewart »
better stil see if you can geta higher rated relay, 28a is getting near to the max of the relay rating,
A lot of OE relays are rated at 40A
Running 2 totally seperate circuits could make sense though.
OK
So I have one non fused circuit through a switch to activate 2 relays
Each relay in turn powers one heater elemement / fan
As each element is rated at 168w I'd down grade the fuse to 15 amps in each relay unit. (I presume 15 amp is available in blade fuses)
All this to get around burning out a simple toggle switch?
No wonder the electronic industry makes loadsa dosh!
I run two relays for my two cooling fans, because they chug alot of power on startup and you have redundancy if something goes wrong.
