Before the car was SVA'd he had difficulty starting - found that the sump was full of petrol
Obviously the scored bores led to conclusion that the carbs may still be leaking fuel - bench testing (carbs fitted to the manifold) reveals that the fuel does indeed go straight through. I have suggested that he test each carb separately to see if one or both are at fault. he did say that petrol was coming out of both sides of the manifold
My thought is that there is relatively little to go wrong on these carbs and that the problem is with the floats. he also thinks possibly damage to the (new) jets or seats.
Any advice/thoughts?
