hiya all,
so i need to check the rocker geometry, before i buy some adjustable pushrods.
Where do i get a set of weak valve springs, so i can check the valve lift easy.
Look on google...but came up blank.
scott
weak springs for checking rocker geometry
- Seight-V8
Re: weak springs for checking rocker geometry
Seight-V8 wrote:hiya all,
scott
If you have an old rocker shaft and springs then use them. Cut them in half and bend the last coil a bit close it off. They work very well!
Pete
As Pete says. Either nobble some rocker shaft springs, or spend a few bob on Valve Check Springs from RS or Crane Cams etc.
But the cheaper option is just as good as the ones in the fancy box!!!
- Seight-V8
