Air intakes & ducting
Hello, my first visit here. I've just put a Rover V8 in my VW T25 camper, my first foray into the world of V8s.
This engine is a touch high for the engine bay, and the original cylinder airbox is even higher. I was thinking of getting some ducting as is common on modern vehicles and routing it to my original VW airbox.
Question is, how important is it that the ducting is the same length to each carb?
welcome mate.
glad we got you signed in ok in the end
Decide how many ponies your engine is making
Have a look at this
http://www.knfilters.com/universal/universal.htm
and from that you can see what airfilter will fit and allow enough air for your application Do not go small or at higher rpm you WILL lean out and do damage to the motor.
Filters do not need to be that big to support a fairly mild engine
Have a look at this
From that it appears that the K&N filter for the V8 has a slightly bigger area than the VW - but there are two of them!
I'll have another think through this - I'm sure I have a Toyota airbox in my shed too, but there has to be a neat way to do this job.
My engine is not highly tuned, and in a T25 I'm hardly likely to be thrashing it, but towing might be more demanding.
The info on that link has changed slightly since I used it as each filter used to have a "for use on engines up to x hp"
Probably worth giving K&N UK a call and asking their advice.
Do you have 1 airbox or 2?
a basic rule of thumb for matching airfilters is generally put like for like. A 1.9 diesel filter is unlikely to support a 3.5 petrol engine type thing as the 3.5 probably moves something like 2-3 times the air volume. Other things to consider are if the filter is too small it will clog far quicker needing much shorter replacement intervals.
This is getting to be interesting. The VW, which was a 1.9 petrol, actually has a larger filter than the Toyota 2.4 petrol. The Toyota engine returns about 125bhp with that filter, which isn't that far behind the estimated 150bhp that I anticipate from the V8.
The only significant difference is that the Toyota is injected while the other two are carb engines, but that shouldn't be significant as the only important thing is the fuel/air mix, and if anything I would expect the injected engine to run leaner than the other two, so requiring more air not less.
I suppose it would be good to find airflow figures to compare.
There is more to it than mixture settings and air flow. You would have to look at service intervals as well. Something that is meant to go a long time between services usually has larger filters all round. Same applies to something that is expected to work in harsh environments. The RV8 also isn't the most efficient engine in the world but still moves a lot of air because of its size. There isn't really any simple answer but if you manage to find a modern say 4.0 engine its filter should be capable of flowing for the Rover. Something like a Lexus or Audi, they also tend to have nice box shaped filters that are easy to package and stash somewhere.
I just looked at the vehicle cross-reference list for the original VW filter : http://www.knfilters.com/search/applica ... od=33-2003.
That includes engines such as the Audi Quattro and Jaguar/Daimler 6 litre V12!
Sounds more than up to the job to me.
