early 875.1
early 875.1
i have a early 875.1 cr block and heads ready for rebuild, if i use comopsite gaskets would this lower cr enough for a 471 charger not to blow by and play havoc pressurizing the sump thanks, any other info on the build greatly apprieciated thanks rover v8
- Rossco
- Moderator Gold
You probably know already that it's the pistons that set the compression on the Rover not the heads.
Composites will drop your compression to around 7.75: which will allow for quite a wadge of boost.
Be carefull though because those earlier pistons are a bit marginal once you get over 6psi.
Allan
Allan
- topcatcustom
blower
ok here,s the plan, old block, which i thought had extra webbing, new rings, bottom end shells and mains, 3.9 heads blower cam with longer exhaust duration rhoads lifters keeping hydraulics, composite gaskets, roller timing chain and cogs , hp oil pump spring new gears, 471 blower 390 holley should be good for 250 bhp in my 110 , but any one have any idea how to plumb in the lpg all built by me with arp bolts
- topcatcustom
