My RV8 wouldn't start a week ago so I bought a new coil and some new plugs. Bingo !! Started first time and took it for a long run without problem.
Some new HT leads turned up which I had also ordered so I thought i'd change those too. Started up OK but does a slight hiccup every so often, not a constant mis fire, its not as obvious as that but just has a moment now and again .
Put the old leads back on thinking it would be back to normal but no joy.
Any idea what it could be ?? Could I have moved the distributor a little ?? I would have thought that would make the timing out all the time ?
I wish i'd left it alone !!
Odd idle on a Rover V8
Do follow the excellent advise that Chris has given!!
I had an occassional misfire too, only noticable at idle, and only just now and then. Everything looked ok, new engine, ignition system, fuel pump, etc...
Then one day I was working in the garage, swithed off the lights while the engine was running by mistake and bingo...out of the corner of my eye saw a tiny spark.... there was one strand of wire, thin as a hair poking out from under the lead cap on the coil, and every now and then the spark would jump to earth, hence the misfire....problem found and solved.
Removed the offending strand...misfire gone.
Ron.
Ron.
4.6 Rover 3500 P6B
