LPG injectors
disco-v8
LPG injectors
Post by disco-v8 »
ok i know if you put an LPG conversion on an engine and its multiple injection instead of the blow back single point injection that fits onto the intake air pipe, you usualy fit injetors that basicaly look like they have come from a pip fitting shop and are controled by a soliniod.......
but is it possible to feed the LPG through the original fuel rail and through the standard injectors??????
by the way my petrol tank is getting ripped out soon so wont need to run petrol through them anymore
Not directly, no. LPG is at a much higher pressure than petrol.
There are a few companies that are either researching or claim to have products which use liquid LPG injection, but they have their own injectors, and usually a pump too.
In a few years there may be an equivalent to petrol injectors, but I doubt if it will use the same hardware.
Return to “LPG Section”
