i will be running water pipes up under my car from engine to rad,
5083 ali would be the best material as its fairly corrosion resistant,
however 6082 is the only one available in a thinnish wall thickness (16 gauge).
does anyone know if im likely to get a problem? im not sure what ali engines are made from, or how much anti freeze will save it from corroding?
Ralph
edit: could use stainless an it would last forever but its heaver and will not conduct the heat out so fast which aint so good.
water pipe material/grade
- topcatcustom
