4.6 firing order
1turbofreak
4.6 firing order
Post by 1turbofreak »
hello
ive got a 4.6 hybrid landrover and ive messed up,she had a misfire so thought a good idear to put on the magnecore cables on ,there my problems got worse.the h/t cables were so badly routed so i desided to pull them all off,i have routed the as per the 3.5/3.9 manual
NOW THE ENGINE IS TIGHT TURNS OVER VERY SLOW HELP WHAT IS THE FIRING ORDER is it the same as 3.5 ?
ive only owned truck 2 weeks im told by old owner its a 4.6 with 3.5 front cover and 3.5 efi manifolds injectors ect
thanks luke
__________________
1.3.5.7 passengers side with 1 at the front of engine
2.4.6.8 drivers side with 2 at the front of engine
GreenV8S
Post by GreenV8S »
If you've removed all the leads then as well as getting the firing order right you need to start in the right place on the dizzy cap. If you're sure they're roughly right, try moving all the leads one position clockwise on the cap, if that doesn't work then try the other way.
You also have to worry about flooding the engine. When you change the leads, put new clean plugs in and make sure the battery is charged before you try to start it.
1turbofreak
cheers guys
battery on charge new set of plugs from halfrads,i will let you know how i get on
1turbofreak
moving leads 1 clockwise has started her timing must be set worng ?
sounds like you fitted the leads wrong :lol:
at least you have found the problem mate,
1turbofreak
thev8kid wrote:sounds like you fitted the leads wrong :lol:
now number 1 is to the left of cap clip,shouldnt it be to the right.
Personally mate i would not worry to much,
cant remember if my number one is to the left or right of the clip,
have you put a timing light on the ole gal to see what she is at???
jrv8
Post by jrv8 »
[quote= now number 1 is to the left of cap clip,shouldnt it be to the right.[/quote]
Hi ,
Most of the aftermarket lead lengths are designed to be fitted , starting at the left of the clip.
Jim
Post by ian.stewart »
No, No1 cylinder can be in any place, its dictated by where the position of the distributor gear is fitted to the cam gear,
The easiest way to get no1 position is remove the LH rpcker cover, remove No1 plug, and rotate the engine untill No1 inlet is closing, insert a small rod or serewdriver blade down the spark plug hole and continue to rotate the engine [by hand] untill the screwdriver touches the piston, gently keep turning untill the screwdriver stops rising, you have TDC, check where the rotor arm is pointing on the cap, this is No1 position.
Ian :D
GreenV8S
Post by GreenV8S »
If the engine runs at all, and the plug leads are connected in the right order, then you can be certain they are all in the correct positions. Unless you've moved the distributor too, you know that the timing is still correct (at least, as good as it was before all this started). As far as I can tell from what you've posted, the HT leads, dizzy, ignition timing etc are all now correct and you're all sorted.
1turbofreak
[quote="GreenV8S"]If the engine runs at all, and the plug leads are connected in the right order, then you can be certain they are all in the correct positions. Unless you've moved the distributor too, you know that the timing is still correct (at least, as good as it was before all this started). As far as I can tell from what you've posted, the HT leads, dizzy, ignition timing etc are all now correct and you're all sorted.[/quot
yes m8 shes up and running again,
still got a misfire,not to sure what to look at next,
fitted new cap/arm/leads/plugs
i will post some pictures of said engine tomoro some of you guys might be able to tell me what ive got. think its been messed about with never seen oil pump housing like it.
thanks 4 everybodys help
Start her in the dark and see if you are getting sparks across the spark plugwires
