help!!! lookin for info plz!!!
hi there, im trying to find out some info for my next project. i want to know if it is possible to put a chevy LS GEN IV 6.0l L98 engine into a capri?? im not sure if it would fit?? any help is appreciated!! cheers guys!!
I believe ford stuck a 302 in a capri and flogged it in South Africa for a while (and it has been done quite a few times since).
Furgison did a capri with a 289 and one of their 4 wheel drive systems, I doubt the transmission tunnel was very standard though and the only one I ever saw had a full cage in it and was a road rally car.
Could always buy the LS with the auto box on the back of it, I think they are quite alot smaller than the T56.
Geoff Uren made V8 capris as well savage Cortinas , but the Basil Green Peranas are the better known, and Peranas were 302s, I have a strange feeling crayford and SuperSpeed either made or were looking into making 302 powered Capris and Granadas
The Furgeson FF system was fitted to Capris, but as far as I am aware was only v6s were made, there were RallyX cars made that were so successful they had to be given time penalties to give the others a chance, I seem to remember they were sponsored by the Daily Express, and driven by a certain Mr Roger Clark.
The FF was also fitted to the Mk4 Zephyr Zodiac and submitted to the constabulary for testing but were deemed to heavy,
A T5 should be ok if you don't go mad with the tuning.
sorry I stand corrected with the FF Capri, thought the one I saw was a V8 but I was only 16, still a very impressive road car!!
Must have been a bit of a dissapointment a FF system in a Zephyr with a ford V4 from what I remember the v4 was quoted at about 55 or 60 bhp, add to that a fourwheel drive system that probably absorbed a further 15 BHP that must have been safe but dull.
The ZZ came with a V4 1700 and 2L also with the 3.0v6kiwicar wrote:A T5 should be ok if you don't go mad with the tuning.
Boosted LS1
UK-Robert ( or username very similar to that ) fitted one to his Capri. He used a TKO600.
it will fit just fine.
Unless the tunnel is vastly different to my car, I'd say the T56 will fit too, with relatively minor tunnel adjustments
