I am planning on fitting a 3.5 v8 into my 1984 LR90, which currently has the rover 2.25 fitted. With a view to doing this i bought a couple of engines that were cheap and now have built up the following collection. I want to build a reliable (but not earth shatteringly powerful) engine to make my 70 mile a day motorway commute more bearable.
I am on a pretty tight budget and so would like to minimise or cut out all together any machining work that you might otherwise pay for on a true stump puller of an engine.
Oh and i run on LPG 95% of the time...
Collection as follows
One 10.5:1 P6 engine, complete but with fairly bad scoring in pots 1 and 3, knackered cam and followers, heads with short reach plugs, and topped of with SU's. Full of black gunge. Full ancillaries and exhaust.
One 9.35:1 SD1 engine, again with scoring- but not anywhere near so bad- Cam and followers showing a fair amount of wear. No ancillaries. Much better colour inside, more brown/gold than black.
One 8:13:1 Early Rangie engine. This is complete with Strombergs and again with full ancillaries. This has not been stripped down yet and so condition is unknown....
So- given the parts available what would you suggest putting together? I realise that the higher compression is going to be much better for my LPG running, but i cant really afford to get the P6 block reworked, and i would be looking at oversize pistons anyway. Assuming the pistons are in good nick, could i put them in one of the other blocks with some honing and new rings? Likewise with the 9.35:1's, would they fit the 8.13:1 block? I have a sneaking suspicion that this has a different size bore to the higher ratio engines but can't remember...
I am planning on changing cam and followers, and the timing gear and chain as a matter of course. Can i fit new cam bearings myself if needed, or is this strictly a machine shop job?
Thanks in advance, and apologies for the essay.
