can the con-rod bolts from the 4.0/4.6 be reused, or must they be replaced....
different people have been telling me different things.
con-rod bolts
It is my understanding that the only bolts used on the Rover V8 4.0 and 4.6 that MUST NOT be used more than once are the factory standard stretch (Torque to yield) bolts used for head retention.
All other bolts are high tensile, ie grade 8 or higher, and as such may be used more than once without detriment. Of course, if the bolt has been damaged in some way, then replacement would be advised.
Ron.
Ron.
4.6 Rover 3500 P6B
