Was thinking of using two of the right hand cast manifolds (HRC1583) on my P6, as i don't have room for fitting the left hand manifold.
Anybody used this configuration? Should be better than the standard 4-1, as i'm after torque rather than top end power.
Anybody any thoughts?
3.5i/3.9i Cast Manifolds
TVRTASMIN
- Helpful or Confused
The two manifolds i aim to use are the shorter of the normal pair. The one where they exit straight down rather than swept back.
I wouldn't have thought i would have clearance issues with the starter though.
I appreciate having to fabricate downpipes, but i was considering using the Range Rover items modified slightly.
They should fit fine then - as you're using the starter-side one on both sides.TVRTASMIN wrote:The two manifolds i aim to use are the shorter of the normal pair. The one where they exit straight down rather than swept back.
