I purchased a Kent cams MDC1 268 and a Vernier Power pulley to compliment it. My mapping is via a Mark Adams Tornado 4.6 hotwire 14CUX.
When it came to fitting the vernier pully my workshop found it impossible to line up the timing marks correctly with those on the cam and the crank. We ended up leaving the vernier Power Pully off from the build and we used a slightly modified standard set of sprockets instead.
The cam came with a set of twin springs so these were installed at the same time along with new stem seals.
After approx 4000km the engine took on some backfiring and popping under acceleration. A strip down of the top end revealed a missing lobe from the cam on cylinder number 3. The tappet was dished also with signs of heat tracking.
My questions are these.
What could cause a single lobe failure? It was completely missing from the cam! All other lobes and followers are fine.
Could the twin springs contribute to such failure?
Is it possible that the manufacturing of the cam is wrong? The woodruff key may have been machined out of spec? Could this be why it was impossible to get the cam timing correct?
My workshop have build a huge number of Rover V8's in their time and yet they couldn't get the power pulley timing marks to line up. They built my previous 4.6 to a very high standard....but everyone can make a mistake right
The cam and tappet was returned to Kent Cams over a month ago but I have not received any feedback as to what could hae caused this.
Any feedback from here would be welcomed. Something must have caused the failure...either fitment,set-up, running in procedure, wrong specs of the cam?
The annoying part of this is that I have paid out hundreds of pounds for parts and the same in labor charges..but no one wants to take responsability for their workman ship or stand by their product.
