I recently finished building a Dax Rush. It's running a Rover P6 engine with a Weber 500. Internally the engine is stock and fairly worn out but it runs ok for now (I'm planning on building a replacement engine over the summer and installing it over the winter).
As I've got more used to the car I've found I'm pushing harder and I have started to explore the performance of the brakes a little. I have found that when braking hard from about 60mph or higher the oil pressure drops very low and on one occasion, plus once more to confirm it wasn't a dash fault, it dropped to 0. I also noticed the engine was struggling to idle for a second or two.
Would I be right in thinking that this is an oil starvation issue due to oil surge in the sump? If so, is there anything I can do to fix it short of fitting a sump with more internal baffling? Could it be that I don't have enough oil in there? It's topped up to the maximum on the dip stick, but could the engine being level in the Rush and being on a slant in its original configuration (Rover P6) mean that I have infact underfilled it?
I haven't explored the limits of the car during turns so I don't know whether this issue manifests itself under hard cornering but I do know that so far it has only been an issue under hard braking so far.
Some people on the Rush owners club have come up with some interesting suggestions, including a few pictures of a DIY trap door sump which seems like a good place to start once I've sourced a Range Rover sump, but I was wondering if anyone on here might have some suggestions for me along the lines above.
Thanks in advance for any advice that may appear.
