No engine number?
paul c
No engine number?
Hi. 94 disco, crank driven oil pump, ten bolt heads, dissy, signs of previous work ( washers under inlet manifold bolt heads, spanner marks on boltheads) had split bottom hose and faulty vac adv, hence overheated, and my cheap purchase. Appears to have tinplate head gaskets, havent pulled the heads yet, but very small gap between block and heads.
Where the engine number should be there are no markings.
My suspicion is previous work, maybe skimming the block removing the numbers, and incorrectly fitting tin head gaskets. This should have composite I believe with ten bolt heads. It would also be 3.9 not 4.0 as it has no cross bolts and hotwire?
Any ideas?
Any ideas?
either skimmed but it takes around .040" to remove them which is a lot for a casual skim or its a new block which don't come with numbers or obviously they are removed to loose its identity. Does the block have the round bosses for the cross bolting? if not then its a old type block just with the newer front cover on. If it has them then it will be a late 3.9. If it has been skimmed that much and has tin gaskets on the newer heads you will have very high compression possibly for a gas conversion?
paul c
Engines out, drivers side head off, first, as that one had the most oil leakage. HRC 2479 heads, tinplate head gaskets, outer row of bolts barely tight.
Whoever has been in this engine obviously new nothing about what they were doing, used old style gaskets and used the torques for old style heads, no wonder it was getting hot, high compression and no advance.
The oil way at the back of the block is not drilled in this block, the tinplate gasket wasnt sealing and the oil was making its way around the gasket and pouring down the side of the block.
paul c
Decided to put the 3.9 block into the 110 with the auto until I get the new engine and chassis completed. Fitted the front cover from a 3.5 and thought I would need a spacer for the crank bolt but found with the pulley fitted all was good. Seems the serp pulley (damper) removed from the 3.9 is much shorter than the 3.5 damper (the amount that protrudes behind the seal), is this normal or is this perculiar to the interim engine. I was expecting the crank to be longer.
The problem that may arise is that I want to use the interim cover and damper for the 4.6.
