chevy v8 oil priming
Hi,anyone know how I can prime oil pump and galleries on a small block chevy without the proper tool or an old dizzy shaft as I want to start my rebuilt engine this weekend,cheers
Er Plugs out, squirt of oil down each plug hole, fill a nice fresh clean oil filter with oil and install, a fresh battery and spin it on the starter till you see oil pressure, the oil pump is a decent design so should self prime (its not a rover
) I am presuming you smothered everything in assembly lube as you built it (especially the cam) so you should be ok. If you are in doubt then pack the pump with vasaline, but you only really do this on the rover as it is a cr***y design.
You could pull the oil pressure sender out and squirt oil down the gallery that way but I would let the pump do it for you.
best regards
best regards
