CYLINDER BOLTS
homateros
CYLINDER BOLTS
Post by homateros »
I HAVE THE V8 3.5 PETROL LANDROVER 90 AND I WANT TO REMOVE THE CYLINDER HEAD. I REMOVED ALL THE BOLTS EXEPT TWO OF THEM.THE TOOL FOR THEM IS 3/8 in . I TRIED TO TURNED BUT THE TOP OF THE BOLT DESTROIED.I HAVE TWO IDEAS.FIRST:TO WELD A LONGER BOLT 10cm ON THE TOP OF THE DESTROIED BOLT.SECOND:USE A DRILL TO DESTROY THE BOLT FROM INSIDE BUT I DONT KNOW HOW DEEP IS GOING DOWN THE TREAD OF THE SCREW.
homateros
Do you have a photo? I can't quite picture which bolt you mean. All the cylinder head bolts are 5/8ths.
P.S. PLEASE PRESS YOUR CAPS-LOCK KEY.
