Hello,
I have just fitted a 3.5 v8 on carbs and I need to pipe the fuel lines from scratch.
Could any one please tell me the inside diameters of the flow and return pipes from tank to carbs.
From memory, I think the return pipe is a smaller diameter to restrict the flow but i cannot remember by how much.
Any help would be greatfully received.
Many thanks,
Graham.
fuel pipe diameters?
I'm pretty sure that you have a return pipe as both my carbed v8's have a pipe going into the left hand carb which is tee'd over to the right hand one and again has a tee pipe for a return to tank line.And all of this is done with proper pipes and olives just as it shows in the parts manual so I expect it's a Landrover/Rangerover set-up.
The only problem is that you cant tell what size flexibles went on to these.
Cheers Graham.
Cheers Graham.
SAGA LOUT
