e.bay has 2 35dm8 dizzys for sale, according to D. Hardcastles book thats the best oe dizzy to have, one's from a range rover, one says its from an efi lump, I'm rebuilding a carb sd1 lump, Question is... is there a difference between the 2? if so, which one would be better for me?
Thanks in advance for any help..
newbie advice please
bak2burbles
I had heard, although I have no evidence of this myself, that the main visible distinction between Lucas distributors made for RR and the sd1 is the location of the vacuum advance module on the distributor body. There is said to be a difference.
I would be inclined therefore to go for the one designated 'efi' as you indicated. Using carbs will not be a problem. You can always have the distibutor regraphed to suit the application if you wish.
Ron.
Ron.
4.6 Rover 3500 P6B
