What are the acceptable piston ring gaps for a 3.9, bores have come out around 3.679/80, 93.48, so the 93.5 normal bore is very slightly undersize.
Ive had my block honed, not come out too bad really, all I can see in the bores is a small nick in the bore at the bottom, probably caused by a rod bolt when assembling the engine, If its not below the ring line, I will be surprised, and even if it is, tuff, its staying like that
