Ok, each rocker cover has a breather hole I did away with the small sponge filter thingy and have a hole there now!
The catch tank would have 2 openings drain plug and sight guage.
Because Rovers have 2 breathers would I need 2 catch tanks?
My understanding is, 1 opening in the catch tank takes the breather pipe and the catch tank holds the oil mist that escapes when the engine breathes and the other opening is then fed back to the inlet manifold. Is this right or is there another way that would not require 2 catch tanks, 1 for each rocker cover in other words!?
Hope Im making sense here
