exhaust position
exhaust position
hi is it best to have the exhaust out the back of the car or just in front of the rear wheels, as space is tight i would like them by the rear wheels any thoughts guys
If you go with side exit like I have in the MGB, just make sure you have an inch or so of pipe clearing the sill. When I had mine flush I did get a few smells.
I couldnt get twins out the back as the petrol tank is in the way. And the new system is 2.5 inch. Ground clearance for me would not be an issue if I hadnt lowered the car by 2 inches. I use the Hedmann budget Turbo mufflers from Real Steel. Low profile flat oval that tucks under quite nice and only about 24 quid each.
I only use this one box each side and it sounds spot on.
