4.0 serpentine engine pulley
Snuggs
Post by Snuggs »
Hi all,
I have just purchased a new 4.0l engine complete with the serpentine front cover and waterpump.
This is to replace my tired p6 3.5l motor in my Luego Viento.
I am aware that the waterpump on the 4.0l runs on the backside of the fanbelt but what I need to know is will the crankshaft pulley from the P6 physically fit on the 4.0l crank.
Hope someone can help.
Clive
spend
Post by spend »
The serp water pump runs the other way round. You cannot run a distributor, unless you buy an interim cover. The easy way to run serp apparently is to buy an alt bracket from JE, which allows a short serp belt to drive just the alt & water pump and includes the adjustment itself.
Snuggs
Post by Snuggs »
Cheers Dave,
I am using MegaJolt for the sparks and was thinking of using an electric waterpump.
As long as the crank pulley will fit then I should be able to use the P6 alternator/bracket.
I know the crank has a longer nose and a spacer is available when using a pre-serp cover but i'm not sure if it will be required.
Clive
The pulley will fit over the crank, and you will need a spacer.
However, whether it will work with the 4.0l front cover, I don't know. I somehow doubt it.
