5.0 serp conversion to early cover?
JC.
Post by JC. »
Is it possible to convert a 5.0 lump with a serp front cover to the early style P6 cover?
Would you be able to run a dizzy on this engine or would some form of EDIS be a better idea?
Image -JC.
will you have a serp front end going begging then 8-)
i can't see no reason why you cant run an early front end, you will need a spacer for the bottom pulley to go over the crank nose due to its longer length,
theres me trying to go to a serp front and you trying to go to an early one :lol:
do you want the sd1 style front like mine then???
JC.
Post by JC. »
There isnt room in an MGB for a serp front end.
The anti roll bar gets in the way. :(
Whats a serp front end worth then? 8-)
Image -JC.
not sure what they are worth, to be honest lots i recon,
has yours got the dizzy hole in?
JC.
Post by JC. »
Not sure mate, I think so.
Its not my engine. I'm just thinking seriously about buying it.
Theres someone on here with a 4.6 MGB who I would dearly love to spank on the drag strip. :lol:
(not that it'll ever happy of course! :( )
Image -JC.
i know that feeling,
but looks like im stuck with me ole 3.9 for now :cry:
chodjinn
Post by chodjinn »
Tony I have a complete serp front end i got with the 4.6 i just bought including water pump. I wont be using it as I also have an MGB - going to be running a Vitesse front cover with either my Group A sump or the Dry Sump kit I just got hold of (if it'll fit hehe) :twisted: :twisted:
Also got the sump and pick up pipe if you are interested? I had a quick look and everything looks in good nick. Its in the loft now and I'm away for the weekend - if ya interested drop me a PM and I'll try to sort some pics out next week :D
you have PM mate ta,
You do know none of the above either with or without dissy are a straight fit on your engine T?
yeah i know the front oil pump will need the key way modding, and Gav showed me how to do that,
what else mate?
Na that's it M8 just wasn't sure if you remembered 8) Oh you will need to do something with the cam as well to keep it held in the right place if its the 4.6 front. Don't know about the inter.
JC.
Post by JC. »
katanaman wrote:You do know none of the above either with or without dissy are a straight fit on your engine T?
What about going the other way???? :(
Image -JC.
if running a dizzy with the old style cover you will need to change the cam i think to a pre serp engine, also will need to fit a dizzy drive gear to the front of the cam,
have the serp front ends got castings to fit a dizzy?
or is that the interim ones only?
interim is the only one that can take a dizzy although now you have to work on the VEMS anyway time to go full ignition as well?
good point,
can the old style block be drilled to take the cam retainer?
if so will my cam need replacing to a serp style one???
also what would i need doing to use the cam sensor and go fully sequen?
