Twin Plenum Throttle Shafts Help Needed.....
Can anyone help me out here :?:
can some one do me a working drawing of the two shafts from a twin plenum please, as i want/need to get some done for the twin plenum,
Allan has the broken ones from the plenum, but i can't get hold of him via e-mail, private message or by phone, :cry: :cry:
And the ones in the plenum now are modified ones,
no body can help then :cry:
topsparks
Post by topsparks »
Try the rover sdi club web site ,they have a tech section and I down loaded the info when I rebuild my TP.
you have a link???
kev_the_mole
Post by kev_the_mole »
Tony,
how long can you wait? I can get the drawing done at work but tolerances might be a bit hit and miss unless the mating parts are available for measurement.
Cheers Ian,
i wanted to replace the shafts before racing next year,
BUT need a pair of shafts to measure as mine are modified and from a standard efi, and are a bit worn and have a bit of play in them,
alex
Post by alex »
Hi Tony
I have a twin plenum lying around in the garage I could lend it to you if you promise to let me have it back again unmolested.
Alex.
hi alex,
that is most kind of you,
if you want to remove both shafts and measure them up for me it wont have to leave you then mate,
and where abouts are you mate??
alex
Post by alex »
Im in Stoke on Trent.
I will take em out and put em in the post if you want after the holidays.
Then if the measurings wrong it wont be me getting told off :D
Alex
:lol: :lol: @alex
Reg, how you want to go about measuring these up mate????
as dont want to be sending alex's shafts every where around the country,
r2d2hp
Post by r2d2hp »
Hi Tony,
If the can be sent to me I will get them drawn up as my brother inlaw is Senior Draftman for BAE.
And then I will see about getting them made.
Is that ok
Alex you ok sending them to Reg????
alex
Post by alex »
Hi Tony
Appologies for the delay in a response.
Yes can send them where ever is easiest pm me an address and will try to sort it out this week for you.
Alex.
r2d2hp
Post by r2d2hp »
Received the shaft from Alex (Many thanks). Drawings have been made at reasonable cost and supplied to tool maker and he is asking how many sets we need as if its a reasonable number will make a jig to help production.
Initial ones will be made in brass but could also make in stainless if required at additional cost.
So if you know of anyone who is in need of replacement shafts can you let me know asap.
Depending on costs i could be interested in two sets mate,
