crower cam 50230!!!! what do you recon???
disco-v8
Post by disco-v8 »
well if you missed my user name ill let you know now, that ive got a discovery 3.9 V8 with some mods already....
ive been looking for another cam to what ive already got and have seen this
crower cam 50230 how good is this cam????
Part Number/Work Order Number 50230
Engine Application 215-340 BUICK
Grind Number 260HDP
ADVERTISED CAMSHAFT SPECIFICATIONS:
INTAKE: Duration: 260º Lift: 0.445 Clearence Hot: 0
EXHAUST: Duration: 266º Lift: 0.448 Clearence Hot: 0
The specifications listed above are based on a rockerarm ratio of 1.6 IN
1.6 EX
RECOMMENDED VALVE SPRING INFORMATION:
Part # 60405 Single Dual X Triple
Approximate spring pressure: valve closed: 105/115 LBS.
valve open: 270/285 LBS.
The information below is for degreeing cam only. Correct only at .050" tappet lift.
INTAKE
Opens: -7.0 ATDC
Closes: 29.0 ABDC
EXHAUST
Opens: 41.0 BBDC
Closes: -11.0 BTDC
LOBE SEPERATION
112º
Duration at .050"
Intake: 202
Exhaust: 210
LOBE LIFT
Intake: 0.278
Exhaust: 0.28
If using "Lobe Center" method of degreeing, cam should be installed on an intake centerline of: 108º
Will take work fitting this cam as you need to check valve piston clearance and you will also need good heads to get the best from it.
