I think something is not connected
- Andy515666
Hi everyone...
I have a SD1 se2 and its been my project car for a very long time! New motor, maual gearbox, new suspension, brakes etc etc.. however my dash does not work now.
the speedo and rev counter do but the temp, oil and fuel are all non-responsive,. The oil pressure light is on but that cannot be correct.
Is there a central point for these gauges where i may have unclipped something?
andy
andy
Chur Bro
Im suprised Ramon has not replied yet, as he is very familiar with these cars etc.
- Andy515666
ramon alban
Gosh Tony, can't an old codger watch a Stephen Poliakof play on TV without being missed (after which I fell asleep over me 'orlicks)?thev8kid wrote:Im suprised Ramon has not replied yet, as he is very familiar with these cars etc.
Anyway, Marki, if it were just the voltage regulator then it would affect only the temp and fuel gauges, not the oil pressure gauge.
So, Andy, because you've lost nearly everything on that side, something more basic is either fuse B3 blown or the connector feeding the green wire from the fuse to the instruments is loose. See here for the 1985 version, otherwise find the same cct diagram for your model in haynes or wkshp manual
http://www.vintagemodelairplane.com/pag ... uit01.html
- Andy515666
ramon alban wrote:Gosh Tony, can't an old codger watch a Stephen Poliakof play on TV without being missed (after which I fell asleep over me 'orlicks)?thev8kid wrote:Im suprised Ramon has not replied yet, as he is very familiar with these cars etc.
Hi Ramon
Thanks for the info. WHen i was looking at my haynes manual.. well I just get lost on the first page of wiring ha ha
no but seriously, cheers, i will go have a play round tonight and probably start with the fuse.
Andy
Chur Bro
i watched it tooramon alban wrote:Gosh Tony, can't an old codger watch a Stephen Poliakof play on TV without being missed (after which I fell asleep over me 'orlicks)?thev8kid wrote:Im suprised Ramon has not replied yet, as he is very familiar with these cars etc.
but i never had orlicks mine was a stella
If the oil light is always on (I assume the engine is running), and also assuming that there is oil pressure!, then it must just be the sender.
The circuit for that is pretty straightforward. If the light is on, then there must be power to that cct.
Unless of course the wiring is mixed up somehow and the oil light ain't connected to the oil light sender.
ramon alban
And in which case the power is getting to the circuits but the oil light on means the gauge read zero and we come back to the voltage stabilizer that is preventing the other two gauges from reading, in which case Andy, it is one of the tin can units about the size of two sugar cubes plugged into the back of the cct board. Marki knows you know!ChrisJC wrote:If the oil light is always on (I assume the engine is running), and also assuming that there is oil pressure!, then it must just be the sender.
Wierd tho'? to have two faults on the same area at the same time.
- Andy515666
ramon alban
Gosh Marki! Help!Andy515666 wrote:Also i have just remembered that the trip metere is not working either.. So would this be all on the same fuse or power supply?
Andy Bro, now we have three things not working Two power feeds to the TC and Interface (if Efi car) unit (J1 and J3) are from the fuse B3 as mentioned earlier and also probably via the same connectors.
There is another power feed to the TC - J4 on fuse C3, so lots of possibilities for the computer crash.
Perhaps you need to do a fuse/connector check for the whole instrument area, before proceeding?
This type of thing:
http://www.vintagemodelairplane.com/pag ... ing01.html
Hmmm as said I don't know the car but when multiple things start acting up or going odd I always start to think earthing problems. Generally there is a lot less earth's/grounds than there are power feeds. One earth dropped can lead to several circuits not working or doing strange things even though they are different fused circuits. Does this sound plausible?
