Before i take everything apart to clean and fit the new injectors, I have noticed there is some black sealant between the trumpet base and manfold - is this necessary?
Reassembling plenum/manifold
kokkolanpoika
Re: Reassembling plenum/manifold
Yes.. If you dont fit this "silicon" sealer then you might get some air leak??chodjinn wrote:Before i take everything apart to clean and fit the new injectors, I have noticed there is some black sealant between the trumpet base and manfold - is this necessary?
Timo
