After driving my new EFi 3.5 back, turned it off for 20 minutes (after driving 120 miles), went back to it and it seems to have developed a small problem.
Got back in, turned it over and it seems to be running on 7? The idle drops to like 400rpm, then it stumbles, ign light comes on, comes back up, stumbles again and will usually drop lower and stall, or not start at all. What an earth? It was fine just a minute ago, has it killed a plug? I've looked through the forums and it seems this might be an ECU problem?
Thanks,
Lewis
(And yes, I realise the cold start injector's off - I did reattatch it for laughs, to no effect. The engine was still warm with some water temperature, too)
