Tremec t45
Tremec t45
Hello, does anybody know if the tremec t45 has a removeable bell housing, is it the same as the borg warner t5. I was hopng to fit one to a rover v8 in a triumph tr7.
T5 is an easy option with bellhousing's being readily available its a better box than the LT77 as well. Another option is an R380 from one of the later sherpas, your existing bellhousing will bolt straight on. Its also a better box than the LT and is probably cheaper than the T5 route. Other options are the Toyota boxes but the bellhousing conversion kit will probably have to come from OZ and are a bit pricey but the box is supposed to be very strong.
Hey.. it's an idea..
A Tremec 3550 5-speed (now "TKO") heavy duty, high performance transmission and a 10" clutch were used in place of the Elite's weaker original 5-speed. (The Lotus 5-speed was taken from a "Maxi", a smaller model exclusive to the European market.) The Tremec 5-speed is the same transmission that Ford used in the Mustang Cobra and also used in a few other high performance cars. The Mustang had a supercharged 281cid (4.6L) V8 with 390hp and 390lbs/ft of torque. To mate the transmission to the engine block, I used a Rover "automatic" bell housing by having a thin 3/8" aluminum plate sandwiched between the two so the internal clutch dimensions worked with the Tremec.
http://www.britishv8.org/Other/RichardNorman.htm
Greg
Greg
