Gas consumption range rover 3.9 !!
wayno
Post by wayno »
When i first bought my rangie a full tank of gas (approx 45 litres) would get me in the region of 120-150 miles.
If i do my maths correctly thats 12-15mpg. More recently it seems to have dropped to around 90 miles on a full tank (9mpg).
My driving style still remains the same. What figure would be acceptable for my car.
Could it be down to the vapouriser ? Someone has told me to try changing the filters ??
softdash3.9
Re: Gas consumption range rover 3.9 !!
Post by softdash3.9 »
wayno wrote:If i do my maths correctly thats 12-15
Is about right, well it's what I get in my 3.9 RR
@12mpg round the doors, @15-6mpg on a run, 12mpg towing trailer/caravan
Regards
Royston
wayno
Post by wayno »
Ok thanks for the advice thinking of getting a new vapourizer anyway as it sometimes doesnt run as nice as it should do.
Chap on ebay sells them for £60 rated for larger engines.
LazyDocker
Post by LazyDocker »
Figures sound good... I get approx 12 round town and as much as 15.5ish on a run from my 3.5. Mind you it is very flat here in Suffolk!!!
I recently pulled my trailer tent back from Cornwall and got just over 14 fully laden from a 10 day break!!
As far as vaporiser goes... Be careful what you get... Some are better suited than others. What system have you got? I personally would start by changing the filters and then look at a service kit for the vaporiser.
If you do go for the vaporiser then the OMVL R30E (I think) tandem vaporiser comes very highly recommended BUT they are a little more expensive and very fragile in event of backfire. I run a BiGas M84 vaporiser as recommended by Tinley Tech in Cambridge as a cheaper, slightly more hardy version and don't have any problems at all (touch wood!!!) All I did was service it when I got it (second hand) and I think all in it's cost me about £30. I would advise you got a new one though as they are only about £70 I think.
Also, check your ignition system regularly for best results. I bought a set of Formula Power 10mm leads, as advertised on here, and have never looked back!
wayno
Post by wayno »
Got a new vapouriser on order. Whats the best way to get it all set up and running correct.
What adjustments are there ? I know my way around a gas analyser, what should the CO be set to ?
Just hope this gets my fuel consumption back to how it used to be !
wayno
Post by wayno »
vapouriser has been ordered from tinley tech today whats the set up procedure.
Setup is complex - TinleyTech will supply you with the written procedure if you ask them.
wayno
Post by wayno »
Filters ? where are they situated
when I had my RR on gas among the delights was a load of gas with water in it, ran even more like a dog and drank the stuff more than usual. I had to have the whole lot drained and all the filters changed. 110 liters of gas into the atmosphere (I had 2 tanks to get some range) and £45 worth of filters and another £70 to the cowboy that fitted the system.
I don't have any filters on mine as such. There's a gauze in the fuel supply solenoid, but that's it!
Maybe injected systems have them, I don't know.
Mine was a ventury set up (mixer) not injection, a filter in each tank, another one just before the vaporiser.
diamond dave
Post by diamond dave »
My Disco is good for 230 ish miles on motorways, which at 57lt fill works out around 18 mpg.
Could do with getting the system serviced & set up again as the fill point bracket has rusted through & needs replaced. Hopefully see 20 mpg afterwards.
Return to “LPG Section”
