router for cutting ally
as the title sugests anyone tried putting a milling cutter in a router and using it to machine ally? or even just a normal router bit?? I want to cut some 1" square "windows" in some 2" by 3/16 wall thickness ally tube and not having a mill this would seem a posable way of doing it.
Re: router for cutting ally
A lot less technical way of doing it that should work would be to mark out the hole then carefully chain drill it keeping inside the lines, then file it out to the final size by hand. A bit of wet-un-dry to clean it up and Bobs your uncle!kiwicar wrote:as the title sugests anyone tried putting a milling cutter in a router and using it to machine ally? or even just a normal router bit?? I want to cut some 1" square "windows" in some 2" by 3/16 wall thickness ally tube and not having a mill this would seem a posable way of doing it.
Your probably looking at 20-30 mins work per hole. (I wouldn't want to do too many this way!)
HTH,
Pete
- ihatesissycars
Jig saw with a metal bit! (Make sure the piece is well clamped and not a lot of pressure on the blade)
Then tidy up the edges with a file or powerfile / belt sander
IAn
IAn
I would drill some corner holes in the right place then join 'em up with a jigsaw and clean up with a file. Use a new high speed steel wood blade and plenty of WD40 or paraffin. I've cut 1" thick ally plate with a normal jigsaw before.kiwicar wrote:as the title sugests anyone tried putting a milling cutter in a router and using it to machine ally? or even just a normal router bit?? I want to cut some 1" square "windows" in some 2" by 3/16 wall thickness ally tube and not having a mill this would seem a posable way of doing it.
A router will do it though, if you have a jig or set up to keep it in line, but use a high speed steel cutter (HSS) rather than carbide tipped, as it usually holds a much sharper edge and cuts better.
Nope there not intended for that, they "may" snatch and shatter, there intended for stainless steel, ready the blades, i'd go for the chain drill and hacksaw method, or jigsaw, or if u can afford it a little cut off saw like machine mart sell, johnihatesissycars wrote:Grinder with a thin cutting disc.
So thats where it went !
thanks folks
I have quite a few to do, at least 8, so the chain drill method would be a pain (though I have not ruled it out) also the drill a 7/8 hole drill out the corners and file it out method. Don't think I'll get the jigsaw in as it is a 1" square hole. I think I'll have a go with a HSS 1/4 inch bit I've got.
thanks again
thanks again
Heres the theory behind it,
http://upper.us.edu/faculty/smith/reuleaux.htm
I did use them when I was an apprenitce, only because I doubted an old fitter when he told me they existed, and because of that I had to drill square holes for a day.
Am I missing something here? You simply drill four holes, one in each corner of where you want the hole, then join them up with a jigsaw cut. Or, you drill each hole halfway along each side, and cut outwards to the corners, but the result is the same. Believe me, I have done a lot of cutting and fiddling about wiv metal over the years.kiwicar wrote:thanks folks
... Don't think I'll get the jigsaw in as it is a 1" square hole. I think I'll have a go with a HSS 1/4 inch bit I've got.
thanks again![]()
