Rush Super Seven V8 4.6 P38
Locha
Post by Locha »
Hello iam Alex from Germany
I have a 4.6l engine in my Super seven. The car was tuned twice and still have problems with the Air fuel Ratio. Iam surching for help.
richardpope50
Re: Rush Super Seven V8 4.6 P38
Post by richardpope50 »
This is a good place to ask but note there is the https://forum.daxsportingclub.com too although several are on both. Air Fuel ratios are not my strong point, I'm afraid. can you give more details of yur setup for others to comment, please.
Richard.
Locha
Post by Locha »
Thanks richard, the car have individually throttle body's and a trijekt ECU . But I have kalt and warmup startproblems. The standalone ECU is very individual but I don't know which numbers belong there. I am searching for the stock Map to assess the numbers.
That is not an ECU I had ever heard of but Google turned this up
https://www.aimtechnologies.com/support ... 01_eng.pdf
Perhaps the more knowledgable here can speak up?
Locha wrote: Mon Jun 20, 2022 5:51 pm Thanks richard, the car have individually throttle body's and a trijekt ECU . But I have kalt and warmup startproblems. The standalone ECU is very individual but I don't know which numbers belong there. I am searching for the stock Map to assess the numbers.
Not heard of that ECU, but pretty well all of them are capable of being tuned correctly. Sadly, this usually needs intimate knowledge of the unit you're using.
If you're not going to learn it up yourself, the rule seems to be fit the make of ECU your tuner recommends.
