Guys, I'm hoping someone on here can help me with this one as I'm struggling for time - not enough hours in a day to spend a day or so mucking about!
Just swapping a 3.5 for a 3.9 (rover) engine on a rangerover for a customer. it has a webber 500 carb fitted and I need to re-jet it for the 3.9. I've no idea what jets are currently fitted as I haven't had it apart yet, but I've got the "re-calibration" kit from Real Steel.
Can anyone give me any pointers as to what jets/metering rods will be correct for a 3.9 with a standard rover cam? Thanks.
Re-jetting a webber 500 carb
Re: Re-jetting a webber 500 carb
Look back through this section as there are dozens of posts about it, giving every possible convolution of what to use, or not to use.badger wrote:Guys, I'm hoping someone on here can help me with this one as I'm struggling for time - not enough hours in a day to spend a day or so mucking about!
- jefferybond
This is 4% leaner than stock (6552 rods, .086 primary jets), and my 3.5 actually ran lean at this setting, and I found out that stock was best. I would use the stock jetting as a starting point and see how it goes. I think the type of exhaust manifold you have makes a big difference to mixture requirements, as well as the cam.gd302 wrote:i read on another website that for a 3.9 engine its 6552 rods and .083 primary jets
Jeff
I use the stock setting for my low comp 3500, and it is a tad rich. But only on the back six pots. The front two always run a bit lean. I'm using the 500 and the offy 360 manifold.
