offset grinding the 4.6 crank
hoffbug
Post by hoffbug »
Can you get a true 3.4" stroke out of a 4.6 crank by offset grinding the journals to use a 2" "small journal" small block chevy rod?
If not what is the maximum stroke you can safely get?
Thanks,Tony
You can sleep in your car, But you cant drive your house!
kokkolanpoika
Re: offset grinding the 4.6 crank
Post by kokkolanpoika »
hoffbug wrote:Can you get a true 3.4" stroke out of a 4.6 crank by offset grinding the journals to use a 2" "small journal" small block chevy rod?
If not what is the maximum stroke you can safley get?
Thanks,Tony
Yes you can get it to 3,4 stroke. And i think all 3,4 stroke crank are std 4,6 crank??
Timo
hoffbug
Post by hoffbug »
I believe the stock Rover 4.6 liter crank is a 3.22 inch stroke.. Id like to try and get it to a full 3.4" stroke.. Basically the same as a Buick 300..
kokkolanpoika
hoffbug wrote:I believe the stock Rover 4.6 liter crank is a 3.22 inch stroke.. Id like to try and get it to a full 3.4" stroke.. Basically the same as a Buick 300..
Yes that i mean..
But i tkink all 3.4 stroke cranks are machined for std rover 3,22 crank..??
Timo
