Hi there,
I've installed a Mocal Oil Pump cover and I'm struggling with the pipework to the remote filter using the pipes I got in the kit (5/8 pipes with 3/4 UNF fittings). Ideally I wanted to fix the remote filter to the inner wing but I can't using the existing pipes and fittings so I thought I'd make up some new ones with alternative fittings.
I thought about buying two 150º connectors but I can't find any that fit 5/8 pipe only 1/2 and don't want to change the existing Mocal fittings to 1/2.
I could make up some longer pipes and house the remote filter somewhere else but not sure where or if this is an arrangement other have used?
In retrospect I should have bought a different pump cover with the connectors already angled upwards but I didn't know what I know now!
Been stuck for weeks on this part of the build so any help much appreciated.
Mocal oil pump cover
- richardpope50
- Gold Member
Re: Mocal oil pump cover
When I bought a Mocal oil cooler the guy gave me a length of pipe and connectors to my own requirements and I fitted them myself - easy. They were all push fit but not possible to get off very easily. It was simply a case of going to a bin of connectors and choosing what I wanted.
Cannot you go to a Mocal dealer and just do the same? Mocal themselves are in West London - went there years ago and they were very helpful.
Richard.
Yes, definitely an option when they're open again.
1978 MGB Roadster
Converting to V8
Converting to V8
Phone Think Automotive
Very helpful and apparently open on line
https://www.thinkauto.com/acatalog/On_l ... gs_53.html
- richardpope50
- Gold Member
Yes, that's Mocal - Think Auto
Richard.
I finally got the hoses connected to the remote filter using 150º & 180º 1/2 connectors with barbs to take a 5/8 hose. I took out the original connectors in the oil cover head (1/2 to 5/8) and simply screwed in the new ones and then attached the hose to the barbs. Straightforward in the end!
I'm now left with the 1/2 UNF oil pressure sender to sort out which fits between the in and out on the oil header . There's no room directly into the cover so I made up an extension.
Unfortunately, there simply isn't enough room to screw it in. All I can do is block off the hole and find somewhere else to connect the oil sender.
Can I drill & tap the remote filter header? Anyone done this before.
Any help much appreciated.
1978 MGB Roadster
Converting to V8
Converting to V8
