Hi All,
I'm building up the 4.0 GEMS engine in my defender 90 (50th anniversary)
it's going out to 4.6, with approx 9.7;1 CR, my big valve gas flowed heads on it.
The heads came off a 4.6 hotwire in a RRC built by Lund with an LE1 camshaft on it.
I liked the setup in the RRC, but always felt like it could do with a little more top-end pull.
What are peoples recommendations?
I recently built a standard 4.6 THOR with a Kent Hi-torque cam, and it was very nice, and ideal for the Discovery 2 it was fitted in, but the defender will be a lot lighter, so would stand less low-down torque.
What do people think of Kent h200, Viper "Stump puller" (if it's available for GEMS), piperbp270.
Would the H214 or piper 285 be a bit too much do you think?
ideas please..
Camshaft Advice please...
- Rossco
- Moderator Gold
Re: Camshaft Advice please...
Just to add a wild card my choice would be
https://www.crower.com/camshafts/land-r ... 0-cid.html
Like you say you can afford to lose a little bottom end in exchange for more power where you spend most of your time.....mid range and above.
Captainbeaky
Mmmm - the "stage 4" might be a little too much - I need to keep the idle sensible.
