Lt77 from a jaguar details?
I have a LT77 from a jag, it has 20A01096450 on the ID pad, carnt find any info on it, is it the same as a Rover SDi item? any info? thanks
Re: Lt77 from a jaguar details?
It could be but isn't there a suffix letter at the end of the number? That would give a better indication of what the internals are. Ratios could well be different to SD1 but knowing BL, they probably aren't.
Ratios varied on the SD1
