Bell housing / Block bolt hole patterm?
turbodave
Post by turbodave »
I've found a few posts asking for this, and one that had an un-finished DXF of the dimensions, but has anyone verified the accuracy of the dimensions?
I'm tempted to use a bell housing off a ZF autobox (as it has an identifiable bore concentric to the centre-line of the crank), clock it in on my mill and the DRO to generate X-Y dims of the bellhousing bolt pattern as a reference. And of course, If I do this, I'll get it uploaded so everyone has the benefit of it.
Reason I'm asking this, is I am looking for a very cheap (read free) way of modifying a mustang T5 bell / trans to mate to the RV8.
I've got a bridgeport, large lathe, tig welder, etc - so why not... I know that I can buy a bell housing, but that's money that I'd rather keep in my pocket :mrgreen:
turbodave
Re: Bell housing / Block bolt hole patterm?
Post by turbodave »
Hmmmmmm, I wonder about just using the ZF bell housing, and mating that to the T5, using a concentric slave cyl...
The ZF bellhousing is very long...
Is this the right one?
BOPC bell pattern, begins in 1964 for Buick small blocks.
https://www.teambuick.com/reference/ident_automatic.php
The Borg Warner 35 also has a round hole to mount the box.
turbodave
Post by turbodave »
Nope, that is the 64 on pattern.
The RV8 is the 61-63 Buick / olds / Pontiac (BOP) 215 cubic inch pattern - and the even rarer 198ci V6 pattern.
Just as well, because I can’t tell what the heck is going on with that drawing! Where are they referencing the dimensions from???
ChrisJC wrote: Fri Jan 26, 2018 10:06 pm The ZF bellhousing is very long...
The TH 180 as fitted to the SD1 has a separate bell housing too - and much shorter.
Stay away from the ZF for 4x4 application bellhousings, they are a lot longer.
