Exhaust manifold gaskets - Differnt sizes?.
jenko
Post by jenko »
Just received my exhaust manifolds and offered them up to the engine...all good.....But I have a set of the metal gaskets which I assumed would fit, but actually they don't line up at all. Am I right in thinking there are two sizes / types of head with the bolt holes in a slightly different place?.
The manifolds are individual primaries (i.e. each has it's own flange).
Building a westfield V8
garrycol
Post by garrycol »
Exhaust layout in the heads is the same on all RV8s - you can put the gaskets on the wrong way around so they dont fit. Look at that first.
What manifolds have you got?
jenko
Post by jenko »
Hummmmm......I thought this might be the case, but I did try flipping them around, turning them upside down, and they were clearly not the right ones....Now, I did acquire the gaskets when I purchased the kit car Im working on as part of a big box of spare parts....So it could be they are not actually for a rover V8.
I will try again tonight and post some pictures.
The manifold is a specific westfield manifold, and that fits perfectly.
DEVONMAN
Post by DEVONMAN »
The hole that the gas flows through is bigger on some gaskets. The mounting holes are the same on all RV8's.
jenko
Post by jenko »
You are of course right....re checked and had the gaskets upside down!.....As homer says....DOH!.
garrycol
Post by garrycol »
Told you so :lol: but dont ask me how I knew all about it :roll:
jenko
Post by jenko »
That makes me feel better...not just me then :-)
