engine casting numbers/ engine number
I have just purchased a Rover or Range Rover short block , but unsure what it is .
It is cross drilled into the crank big end caps, the engine number is 60D11306A
block casting number WYF 15 HRC2411
I am in NZ so dont know if is different from rest of world because cant find that engine number or block number
Any ideas ?
Tim
Any ideas ?
Tim
Cheers Tim
That is a Thor 4.6 High Compession engine.
http://www.rimmerbros.co.uk/content--na ... ne-Numbers
4.6 will be cast into the front crankshaft counterweight.
Garry
Garry
At $100 it's a gift. You'd probably pay more just for a set of pistons.
As for the blower, I'd think you would need a set of low compression pistons or a few head gaskets stacked to drop the CR down a tad.
You've not got much to lose, stick it in and play with it. If I had that bottom end lying around it would be getting heads and 2 turbos right about now with the only debate being my P38 or P6 as destination.
I have 4 new sets of head gaskets to $50 that was 4 x metal gasket and 4 x composite gaskets , I guess depends on how much boost i let rip through , apparently can change with pulley size or blow off valve , I was only going to use 3.5 block but this thing looks like its so much stronger with the cross bolted main
Cheers Tim
Cheers Tim
Cheers Tim
Cheers Tim
