I'm planning on changing the heads on my 3.5 to 4.6 spec heads.
A few questions please.
Does the 3.5 rocker shaft assembly fit the 4.6 heads?
Which method of tightening should I use please?
10 bolts to 70lbft or 25Nm (18.5 lbft) then +90° and +90° again
Does the type of gasket make any difference?
Would the composite gasket affect the valve train pre-load?
Thank you
Mickey
4.6 Heads on a 3.5
mickeymonk
mickeymonk
