Setting up and balancing quad twin Jenvey ITB's
mgbloke
Post by mgbloke »
Hello all.
can anyone tell me a method or point me to a method for setting up the idle and balancing my ITB's. I have a vacuum gauge just cant remember the procedure.
Mark
JP.
Post by JP. »
Warm engine. ( 20 mile drive so engine is fully warmed up en valve clearance is fully equal ).
Fast idle ( 1500 rpm ) so all throttle cable and rods slack is out.
Start at the last ITB and work your way back to the first one on the throttle cable.
'73 Ford F250, 6.7ltr V8
Building a GT40 mk2
mgbloke
Post by mgbloke »
Thanks JP
My jenveys have an air bypass valve on each one for adjustment. Presuming the butterflies should be fully closed and balance airflow with the bypass.
Just wondered if there was a certain procedure.
Mark
Call them up and ask them for a manual on how to set them up.
mgbloke
Post by mgbloke »
Yes I have tried emailing them but as yet no reply.
will give them a ring.
mark
JP.
Post by JP. »
mgbloke wrote:...Presuming the butterflies should be fully closed and balance airflow with the bypass.
Butterflies should be slightly open, hence the 1500rpm I mentioned.
Fully closed is idle only and you want all the throttle blades open simultaneously.
Building a GT40 mk2
kokkolanpoika
Post by kokkolanpoika »
This is what i did..
8x vacuum cauge´s. Thanks for my friend sponsoring those cauge´s very cheaply..
I have to setup my idle vacuum for emission reason´s, then i check that high rpm vacuum is similar both side.. approx 1500rpm. In my mind better option is a road test..
I also have got special tool that i can measure throttle plate and body clearance when they are fully open..
Timo
