rover v8 3.9 efi
does any one have any ideas why this may be happening?
the injectors have been refurbed recently and replaced and i am now running through all the checks to find out why the engine is running rich.
the oil breather pipe has been checked for blockage along with its filter. the potentiometer has also been checked for the correct voltage
constant popping and banging on idle and revving
bennyboy79
Presuming it is a Hotwire and 4CUX brain/ecu
Reset the ecu bu disconnecting the battery for at least 30 seconds and then reconnecting
Will clear down error codes and if it is on limp home mode will clear the over fueling
