no 1 - 120psi
no 2 - 150
no.3 - 150
no 4 - 150
no 6 - 10
no 7 - 150
no 8 - 10
So, no 1 possible rings? but numbers 6 and 8 barely any compression at all which has got me thinking. Being neighbouring cylinders could it be one shared problem such as head gasket. The engine does not overheat or use water, neither does it use lots of oil - or blue smoke.
Could there be any other explanation such as incorrectly set lifter pre-load.
I would like to eliminate anything before taking heads off. Thanks in advance - Andrew
