4.6 rv8 retaining plate
capriandyb1
Hi guys iv got a crower 50232 cam ordered for my 4.6 block,im running the 3.9 front cover and dizzy.my question is.can I run the cam without the retaining plate ???
I have read that you can't use the half moon retaining plate that's on the 4.6 as standard with the dizzy gearing and v8 tuners and real steel say the full moon plate is no longer available
Any help would be great
If you are running a dizzy driven oil pump then yes you could get away without the retaining plate as it is the load that the oil pump puts on the dizzy that stops the cam moving forward. Having said that I run a plate on my 4.6 even though I have an old style pump. If you are running a crank driven pump then you must use the retainer plate.
capriandyb1
I'm running a full circle retaining plate. I'm also running vernier timing gear, the bolts that hold the plate in plate foulded the cam sprocket so I carefully ground down the head of each bolt, from memory they ended up pretty thin, maybe 3mm thick! You could counter sink the plate and use counter sink screws with some thread lock.
capriandyb1
I run the full cam plate and Vernier gears and didn't have to grind the bolts down,
took a while to find the correct Vernier gear set to work, and its a kent cams set that clears just for future reference
Rimmer Bros still list both full circle
"Cam Retaining Collar" ERR5926
And the part circle type
"Camshaft Thrust Plate" ERR2609
I don't know if they still stock them, but I'd assume so...
FWIW, I'm running the same gear as Sidecarbod, and countersunk the bolts (I also made my own plate, because I'm tight)... If you make your own, be aware that the mounting holes are not on a diameter, they are offset, so the plate only fits one way. It's impossible to fit it the wrong way if you buy one (because the second hole won't line up) but if you machine one and assume the holes are on a diameter, it won't fit (ask me how I know).
capriandyb1
benjai wrote:Rimmer Bros still list both full circle
Can I ask what size are the bolts that fit the cam plate
Current project
1972 mgb v8 4.6 roadster
- SimpleSimon
Tony the early KC verniers didnt clear the bolts or plate (Its why TVR deleted the TP on some builds inc mine that came fitted with the KC venier in the mid 90's) but the later one's do these are the ones we must both be using nowCoops wrote:I run the full cam plate and Vernier gears and didn't have to grind the bolts down,
Can't remember for certian, but Rimmers say they are 5/16 UNC x 3/4 (as a hex head without countersinking). I expect in this case, 5/16 UNC x 1/2 CSK would do, but I expect I bought them at 3/4 long and then cut them down for maximum thread engagement...BISH V8 wrote: Can I ask what size are the bolts that fit the cam plate
capriandyb1
