So, lots of questions.....
1). The oil sump pick up - My set up uses a non distributor serp cover, the oil pump cover is the one with the pick up pipe connected to it. So this means that the block has a pick up port cast into it that is not going to be used. Assuming that a fair few have this set up, Rover must have blocked the cast in pick up port with something...Anyone know what?...or do I just make something?.....See pic:
2). My set up will need an oil cooler, and from a previous post, it would seen that I might as well use the oil cooler connections on the timing cover...Problem is, I have a vague recollection that I read somewhere that one of the relief valves needs removing (there are two)...or did I..don't know cant remember....can anyone advise?.
3). On the subject of the relief valve in the timing cover, I've seen pics of a relief valve with a tube inside it....My timing cover does not have this tube...anyone know what it's for, and if it's needed?
4). What a dipstick! - so, the block is new, and never used....where the hell does the dipstick go, I see no holes / casting for it's entry point. The sump gives away no clues either. Try As I might on good old google images, I cant find a pic that shows where the dipstick enters the block....And just to prove it:-) here are some pics of the block.....
