cylinder head gasket - bore diameters
Seight-V8
Post by Seight-V8 »
hello all,
I've had my rover V8 4.6 block top hatted a while back, and the bores machined to match my current 94mm +0.50mm pistons.
I notice head gaskets come in 94mm and 96mm bore sizes....
Am I best going for the 94mm one and being a little undersize, or going for the 96mm one and being a little oversize.
Baring in mind I don't have any chamfer at the top of the bores like the standard LR ones, as the top hats are pretty square at the top.
scott
SimpleSimon
Post by SimpleSimon »
The OE Elring gaskets are more like 95mm IIRC I can check on monday if you like I have a used set for just these measuring purposes
8-) very slight gasket protrusion into the chamber is not an issue its when you have lots of the fire ring in the chamber things become as issue :cry:
Blown v8
Post by Blown v8 »
John Eales sells 95mm cometic ones
SimpleSimon
Blown v8 wrote:John Eales sells 95mm cometic ones
A mate of mine as just gone down this road with a 5.5 RV8 and got the 96mm from JE's he as a bore of 95.5mm IIRC :wink:
